Is this gear damage repairable? (photo)
Bruce L.
09-16-2003 08:33:09
third party image
This is the 4th and 6th speed gear for a JD 50. I bought this one used to replace one that is in even worse condition. This one has a couple teath that are chipped at the edge. Could this or should this be repaired in any way?
John
09-16-2003 21:26:16
 Re: Is this gear damage repairable? (photo) in reply to Bruce L., 09-16-2003 08:33:09
Man, I would be happy if my gears looked that good! Looks like the tranny of an "average" tractor. Most people are hard on non-syncro transmittions. Gear damage on the edges really isn't that big of deal. It would take a complete missing tooth with damage on the two adjacent teeth before that gear would ever fail. Unless you have 900 cubes and pull the 15,000lbs classes I wouldn't worry about it. Deere way over engineered all the 2 lungers especially in the transmittion. Just my two cents worth you probably can find a better looking gear cheap but it might be a weaker gear than the one you have. Just a thought.
John
Diesel Don
09-16-2003 19:59:08
If you know someone who could weld the teeth and maintain the heat treating of the gear it could be repaired, but cost would probably be high. I just rebuilt the tranny in an A and there were some gears that were in much worse shape than that one. I did have one that was roughly the same as the one in your picture and I decided after taking it apart and doing all of that work, I wouldn't risk putting back any gears that looked even remotely like they would fail. If you can find one, replace it. If you can't, that one probably would run for years as long as it was used for light service.
Bus Driver
09-16-2003 16:29:03
I have seen gears looking worse than this that were fine in service. If you have the choice to shim the gear forward or back to get full contact with the mating gear, be sure to do that. Looks like someone tried some speed shfting. Shifter forks in good condition and properly adjusted are also important.
Aaron
09-16-2003 09:28:37
If you can't get any other, and you're not going to use the tractor for heavy field work, I think you could get by. The best choice? No. Workable? Yes. As stated, this is a common gear and another should be available.
ChuckW
09-16-2003 09:19:31
I wouldn't try any repairs, however this is a real common gear and should be available...this is the slider and get the brunt of shifting on the run or grinding. I believe the late model B is the same gear. I would return and look for a better one.
