How would you fix this shifter??
Scott
09-16-2003 03:56:57
I have a 1941 JD B Electric start, and the shifter level pulls up. I know there is a keeper ring on the other side of this shifter that is suppose to hold it in place. How would you guys fix this. I have one week to get this tractor fixed so I can use it in the Homecoming parade.
Thank you to those who answered my early posting of this question, but I need to know more specific how to fix this problem, and fix it good.
Scott.
Clooney
09-16-2003 15:42:55
 Re: How would you fix this shifter?? in reply to Scott, 09-16-2003 03:56:57
Scott, I don't use the stock Deere snap rings in those old worn shift lever grooves [they don't hold very good if the grooves are worn with rounded edges or rusted up]..I use a double external snap ring [the kind that has the two little holes & needs a snap ring pliers to install]..Those external snap rings [available from most auto parts stores] hold real good & there is enough room to usually double them up so they can't get pushed out of the groove again.
Mark
09-16-2003 15:18:39
It's down out of site, so I would drill a hole where the snap ring would go in that worn out groove and drive a roll pin through it.I've done it a couple of times and works great.
ChuckW
09-16-2003 12:17:14
as F.I.T. advises use new lock rings, be careful and not expand them anymore than necessary in installing. I would use a small file and carefull square up the edges of the grove if necessary, wouldn't make it any deeper. If it is real bad I have in the past welded the lower ball in place with a lower beed. Don't really like weld there as it would come loose and get into gears but a good job will hold. Also you might braze, softer metal. If available another unit might be in order. I think all the shafts are the same in B's maybe in other models also. Anyway my 2 cents worth.
F-I-T
09-16-2003 06:20:15
third party image
Scott:
I would shift to dead center neutral and lift the shift quadrant up and replace the two snap rings. Hopefully the lowest one is just worn and not the slot. I have seen folks have to drill a small through hole and use a pin or cotter key to hold the spring pressure up.
Frank-in-Tallahassee
70D // 855 // VAC
