Paint mixture question
John
09-15-2003 20:26:38
What mixture ratio of JD paint and reducer should I use? I have a gravity feed HVLP gun. Will be using hardner also. Thanks very much for the info,
John
Clooney
09-16-2003 03:12:18
 Re: Paint mixture question in reply to John, 09-15-2003 20:26:38
John, you will have to play with the reducer ratio a little to get the paint to lay down flat depending on YOUR painting style, gun, speed, & the ambient/metal temperature & humidity.
~I would start at about 8 [paint],,2-3 [reducer],,,1 of [hardener]. ~Personally I don't use Deere reducer as that is a single temperature. I use Synthol synthetic reducer in the temperature range I'm painting at & usually mix 10/3/1.1 but will vary the reducer ratio very slightly depending on the age of the paint, the weather, what I�m painting, if vertical or horizontal, air pressure used, & what coat I�m putting on. It usually stays between 2 & 3 oz per 10 oz of paint.
~A cheap gun or low air pressure might need it slightly thinner to atomize correctly..
~The one advise I can give you is try different reducer ratios until you get the results YOU want. What works for others might not be correct for your equipment & painting style.
