3020 MS Carb. Question
Clark McGrew
09-15-2003 19:53:51
I have a gas 1966 3020 that runs rich, floods easy and fouls the plugs.
I rebuilt the MS USX 36 carb that was on it.
On the accelerator pump housing is seat, check ball and spring. When I disassembled the carb there was no check ball. Or at least I never saw it.
What was the purpose of the this check valve?
Would the tractor have run with out the check ball in there?
I could not find a replacement. Local JD dealer diagrams don't even show it.
I replaced it with a piece of No.4 steel shot.
When I put the carb back the tractor fired right up. Smoking and rough running seem solved.
Biggest problem I found during the rebuild was that the needle valve did not close soon enough.
Added a second gasket below the seat and it looks good. However, I'm still curious about the check ball.
Thanks,
Clark
Bob
09-15-2003 20:05:32
 Re: 3020 MS Carb. Question in reply to Clark McGrew, 09-15-2003 19:53:51
Although I am not familiar with this carb, generally there is a check ball in the accelerator pump system to prevent fuel flow through the system when the accelerator pump is not moving and actually pumping fuel.
Clark
09-16-2003 20:05:57
 Re: Re: 3020 MS Carb. Question in reply to Bob, 09-15-2003 20:05:32
Thanks Bob.
That makes sense. It would also fit with the problems I was seeing.
Tractor always seemed flooded when I went to start it. I would actually drain the carb before trying to start.
With the needle valve not completely shut and no check ball to stop the gas from flowing through, the carb probably just filled up. Often times there was gas on the air intake side of the carb.
Thanks, again.
Clark
