4430 Loader hydraulics
smurph72
09-15-2003 16:32:41
My cousin/employer has a 4430 with FEL. Is the hydraulic reservoir a common sump for the transmission or do I need to check the hydraulic fluid level elsewhere?
Transmission operates without problems. The loader vibrates/shimmies going up or down ever since installation. I think there's air in the system or it's low on oil. I found the dipstick above the three point. Shows full.
I'm alot more familiar with Farmalls, and this Deere has me puzzled. I'm ordering a manual, but thought I'd try here too.
Thanks for any info.
dcm
smurph72
09-18-2003 08:03:17
 Re: 4430 Loader hydraulics in reply to smurph72, 09-15-2003 16:32:41
Additional info-
The loader is plumbed into the remotes at the rear of the tractor. It's a mid 1980s model with what I think is the powershift (Release the clutch and you can shift up or down through the gears without the clutch).
Thanks for the help.
dcm
Brokenwrench
09-15-2003 17:18:45
The transmission acts as the reservoir. Some more info would help. Year of tractor, quad range or power shift,how is the loader plumbed to the tractor,through the remotes or a power beyond block behind a remote?
smurph72
09-20-2003 16:56:50
 Re: Re: 4430 Loader hydraulics in reply to Brokenwrench, 09-15-2003 17:18:45
Additional info-
dcm
twopop
09-15-2003 18:00:21
the main hyd pump probably needs rebuilding.one or more of the intake valves are leaking.
