47 B ROCKSHAFT WILL NOT LIFT
CHUCK BARBER
09-15-2003 14:58:49
I BOUGHT A 47 B WITH A FRONT END LOADER. THE LOADER WORKS FINE AND THE HYDRAULIC PUMP DEVELOPS 750PSI, BUT I JUST BOUGHT A 3-POINT HITCH AND CAN NOT GET THE ROCKSHAFT TO LIFT. I TRIED TO ADJUST THE METERING SCREW AND THROTTLE VALVE. THIS DID NOT HELP. I REMOVED THE POWERTROL UNIT AND PISTON, BUT THE PISTON CUP DOES NOT LOOK THAT BAD. DO I NEED TO USE OIL LINE PLUGS (DONT HAVE ANY) OR CAN I USE THE OIL LINE COUPLINGS OFF OF THE REMOTE CYLINDER WITH A PLUG IN THEM? ALSO IN ORDER TO DEVELOP PRESSURE TO USE THE LOADER I HAVE TO PUSH THE CONTROL LEVER BACK WHICH I THOUGHT WOULD TAKE PRESSURE OFF THE SYSTEM NOT PUT IT ON. IS SOMETHING INSTALLED BACKWARDS? PLEASE HELP CHUCK
Clooney
09-15-2003 15:23:37
 Re: 47 B ROCKSHAFT WILL NOT LIFT in reply to CHUCK BARBER, 09-15-2003 14:58:49
Chuck, you will need the open front plugs in those ports for the rockshaft to work. The passages for the rockshaft are in front of those plugs so the fronts need to be open for those passages to get hydraulic oil pressure. ~You could also move the front end loader plumbing to the P/T side ports then use the selector valve to divert pressure to either the loader or rockshaft.
~The lever direction for the remotes depend on what port you have the pressure line in & what side you have the P/T lever on..
[email protected]
