38 unstyled B
charlie
09-15-2003 14:34:02
My 1938 B has two 3/4 " plugs ( one high and one low) on the bearing housing behind the hand-start flywheel. Can someone please help me with this. I thought that this bearing housing rec'd oil from the crankshaft, or does it take 90 weight. Thank you very much.
p.s. How do I check the level if it is 90 weight?
Clooney
09-15-2003 15:17:52
 Re: 38 unstyled B in reply to charlie, 09-15-2003 14:34:02
Charlie, those pipe plugs are to access the main bearing bolts [so they can be removed], the nuts for those bolts are exposed on the other side..
charlie
09-15-2003 18:02:02
 Re: Re: 38 unstyled B in reply to Clooney , 09-15-2003 15:17:52
Thank you Clooney
