3010 diesel starting problem
Larry
09-15-2003 07:36:12
I have 2 nearly new batteries in my 3010D. I took out the left battery the other day to install a new battery box and now the tractor will not do anything. The lights come on dim but no starter at all. Did I lose my ground or what? I cleaned the terminals and tightened connections but nothing changes. Help!!
Rodney A Johnson
09-15-2003 10:21:14
 Re: 3010 diesel starting problem in reply to Larry, 09-15-2003 07:36:12
Double check to make sure you connected the cables to the correct posts on the battery. If your 3010 is still a 24 volt system you may have hooked it up such that your two 12 volt batteries are in parallel instead of serial.
There are two ways I have seen the 2 12 volt batteries hooked up to make 24 volt. One way is where the frame of the tractor is used to connect the two batteries in serial (cable from one batteries positive to the frame and another cable from the negative of the other battery to the frame). The other way is where they use a cable to connect the two batteries (cable goes frome the positive of one battery to negative of the other battery...the other posts of each battery connect to the starter) and use a small fusable line to connect to the frame (to get your two 12 volt circuits).
If you are not sure if your tractor is 12 volt vs. 24 volt, check to see if the battery cables connect to two separate studs on your starter...one on the solenoid the other on the starter in back next to the engine block...if this is your setup, you have 24 volt.
Hope I didn't confuse you with my rambling description...
