Float set and top vent bafffle - dltx71
JE
09-15-2003 07:12:51
Can someone please give me procedure for setting float level on DLTZ 71 for 48 model A? Also, where is the top vent bafffle on this carb - i've heard if this is plugged it can make the tractor run poorly.
Clooney
09-15-2003 16:16:13
 Re: Float set and top vent bafffle - dltx71 in reply to JE, 09-15-2003 07:12:51
JE, I don't have a carb chart handy but believe the float level is 3/8" below the float bowl gasket surface. To set, invert the float bowl so the float is resting on the closed needle/seat then measure the distance from the top of the float to the bowl gasket surface. When the float is set correctly the fuel level in the bowl should be about 3/4" below the gasket surface as the needle shuts off... Personally I just set the float top parallel [level] with the bowl gasket surface.
~On the bowl vent..it is a hole in the top of the carb body casting [inside the bowl area] in a [about 5/16"] recess between the center stem & throttle shaft side, that hole leads to a passage that goes into the choke area of the carb & also leads to the economizer passage. There could possibly be one or two hat shaped baffles in that hole on the later carbs. The early carbs didn't have those baffles but in some cases they were added as a dealer fix for rough ground flooding.
[email protected]
