520 value
texas jack
09-15-2003 06:18:05
there is a 520 narrow front , 3 point in fair condition coming up on an auction. The tractor looks complete ,but worn and is said to run. Any suggestions about what it will cost to buy? Also, what sort of problems do I look for? I am a complete amateur, so any tips or thoughts would be appreciated. Thank you.
Jack
ellis b
09-15-2003 16:40:52
 Re: 520 value in reply to texas jack, 09-15-2003 06:18:05
Can't say about the price, I traded 3 Limousin heifers for a 730 LP about 6-7 years ago.
Be sure and LOOK at where the flywheel is mounted on the crankshaft, on the left hand side, due to the possibility of it being operated with it loose on the splines. This is the weakest point on these engines. I have a 520 LP that I bought out of a dealers junk yard in Crockett about 20 years ago. It had a badly messed up FW and crank but I fixed it by welding the crank, machining it and the FW and then drilling and tapping for cap screws. It was a rather easy fix, but you have to know how to keep it in time mainly due to the FW having a counterweight built in it. Where in Texas? Do you hook'em horns or gig 'em.
MIKE HANLEY
09-15-2003 08:30:12
There is no way to know what is the tractors shape, unless you buy it take it home and run it for a while. Is it a working tractor at a farm acuction, or something brought in at a consignment sale? If a working tractor at a farm sale, talk with the neighbors. They will know about how the guy takes care of his stuff and if indeed it is a working tractor. Is there a local JD dealer near by? Talk to both the service guys and the parts guys. They may know the tractor. If at a consignment sale, it's anybodys guess as to it true shape. When the two bangers were the main tractor on the farm, they were taken care of pretty good, as time goes on and they became the backup or wagon hauler, the maintaince slipped alot on those tractors. At the sale stay by the tractor and keep your eyes and ears open. There will be all kinds of guys starting it and looking it over. Pay attention to what they look at and what they say. There are so many things that could not be working just right, but could be just a matter of ajustments or could be big bucks, and there is noway of knowing till it's home. You need to know what you will use the tractor for and what you can live with and the shape of what you see. If you are useing it on small acreage and plan on useing it and keeping it for years to come, keep in mind what a new tractor would cost to do the same thing. Then it will not be so bad when you have to change some parts. If it's nearly 50 years old and still running, by bring it back to top working order, it will last a long time yet. You can drop a $1,000 into it and never do anything mecanical to it. Meaning new meldalion, screens, seat, new bushing and rubbers in a float ride seat, new seat, battery box, new muffler, new steering wheel, etc. If the rims are rusted out and it needs new tires, that could chew up another $1,000. Or can you ive with what it looks like now. If you get the tractor, get a operators manual. a shop manuel and a parts book. THIS IS A MUST! First thing change and flush all the fluids. Do all the service and ajustments that the operators manuel says before using the tractor. The value of that tractor will be set when the auctioneer yells SOLD. Some guys think that a certian model is worth XXX many dollors. But that can't be, as just looking at a tractor will not tell you if, it was overhauled several years ago or if you have to pick up the tab after you buy it. A tractor you can run for years is worth alot more then the same model as one that needs alot of work. If someone says that a certian model is worth say $5,000 and you put another $5,000 into it and the guy says still says that model is worth only $5,000,,,well,,,I'd be as polite as I can telling him to leave. GOOD LUCK.
