Deere 310-A Back Hoe
Bill
09-15-2003 03:23:16
I have a John Deere 1978 310-A Back Hoe and while I was running it along on flat ground in the transport position I heard a loud bang and discovered that the Pressure Control Valve which is located on the right side of the machine and bolts on to the side of the transmission had cracked the cast iron pressure control valve body almost the entire length of the casting. Has anybody out there ever experenced this and know what could have been the cause of this failure? Also, not being a professional mechanic is their anything special I should do when installing a new one? Thanks Bill
david val
09-18-2003 15:25:36
 Re: Deere 310-A Back Hoe in reply to Bill, 09-15-2003 03:23:16
seen it happen a few times. there was a replacement part # years ago but it happened to the new part too.
david
rob nickel
09-23-2003 02:48:48
 Re: Re: Deere 310-A Back Hoe in reply to david val, 09-18-2003 15:25:36
Never had this happen to me in the 26 year's I operated backhoe's for a living but the only rubber tired machines around for this type of work is the Case 580, 590...etc..? All other backhoes in this size range pale in comparison and I wouldn't buy anything but Case as much of a jd man I am?
