520 LP Update....on Pistons
Tyler-MO
09-14-2003 20:35:28
third party image
I just got finished with removing the pistons rods and block from the 520lp. I fount a few surprises....both pistons top rings were in pieces. Pistons are visibly worn on top and bottom. Exhaust valves cracked, intake valves worn beyond belief, and of course the naturally occuring exhaust manifold bolts broken off in head. What a day....but hey that's what makes this hobby fun right! I did find that the rod bearings and pistons are the original stock part numbers not oversize. So at least I am pretty sure it is original. I haven't measured anything yet...that will come soon. I'm wondering on getting an opinion as to what would be the better route to get her back running the best. I've had suggestions to use the old pistons and sleeve it to fit the worn pistons. or to get a machine shop to custom make a set of LP domed pistons for me. The other option brought to me was to get a set of aftermarket gas pistons .045 oversize and have someone "build" them up with aluminum welding rod and have high domed. I'm wondering which would be the most cost effective and which one would last longer. --Another thing is my extremely worn intake valves. I am planning on putting in All-Fuel intake valves as they are larger than stock LP or gasoline. My question is when the valve seats would be ground that would only sink the valves farther into the head causing the compressions to drop....can you put hardened seats on the intake valves as well as the exhaust?? I suppose that the machinest near to me would know but here I was typing anyway. Well that's enough for the evening. I greatly appreciate opinions and ideas. Thanks
Tyler in Missouri
Larry
09-15-2003 03:38:58
 Re: 520 LP Update....on Pistons in reply to Tyler-MO, 09-14-2003 20:35:28
Just a thought...I wonder how much compression loss you'd have if you were to use gas pistons??
I overhauled a 4020LP this spring, and I had a couple of people suggest using gas pistons, they claimed the difference would be negligible. I used the correct LP pistons, so I can't tell you what the difference is.
