Good Evening Don, Since you say the tractors have set a while but they need a lil choke to keep them running, here is a troubleshootign proceudre that hopefully will be enough to get you started. Although theres lots more that could be said on the subject, if this does not suffice, you can post back or e mail as noted below and we will dig deeper. Accordign to all the e mails and feedback I get, some prefer every possible in depth troubleshooting detail up front, while others prefer to take it one step at a time, so I try and cover as much as possible subject to my time limitations on this first post. If I miss something, I apologize (been a long day lol) and will respond after you first try these tips. Theres a good chance you just need fresh gas OR new plugs OR the carbs top load and idle needles need adjusting (see below), but if she still needs choke depsite all the preliminary tests below, then there may be restrictions in the carbs main center brass vertical nozzle, in which case it may need removed and cleaned (see below). Also, the float level may just be too low or theres a minor restriction in the needle valve and seat or in the sediment bowl assembly or even the carb top vent baffle is plugged. Try removign the glass sediment bowl and clean it and any screen out and let clean fresh gas run a while to purge any water or dirt and try it???? *************TROUBLESHOOTING*******************
1) Since they have sat a while, the gas could be stale and/or have some water in it. Fresh gas and making sure there's no water in it or water in the air cleaners lower bowl is a good first thing to check. Open the carb bowls lower drain cock/plug and let the gas run a while to drain any old stale or watery fuel and have fresh clean gas in the tanks. CHECK AND CLEAN THE AIR CLEANER BOWL 2) You might want to inspect and clean or replace the spark plugs if they appear fouled or heavy black carbon coated. A fresh set of plugs can do wonders if the old ones are even partly fouled. Insure BOTH plugs are firing a good visible blue and NOT a faint thin wimpy yellow spark. If they are weak, post back or e mail your ignition type for my Ignition Troubleshooting Tips. 3) Once you have fresh clean water free gas and good plugs, you might try to adjust the carb top load and idle needles to see if it helps. The initial rough in start carb needle settings are closed down then 1 3/4 to 2 turns out for the idle needle and 3/4 to 1 turn out for the load needle. Try adjusting them and especially richening (open out) and see if she still needs choke????? ???? 4) If the plugs are good,,,,, , and you have a good hot blue spark and fresh clean water free gas,,,,, ,,,, but she still needs choke to run despite carb needle adjustments, then try the below: 5) With the gas on at the sediment bowl, open the carb bowls lower drain cock/plug and insure a continuous stream of gas approx 1/16 inch in diameter flows out continuous a couple minutes or so. If not, theres a flow restriction either in the needle valve and seat OR the carbs side inlet strainer OR the sediment bowl assembly OR its inlet pipe area or other places. 6) Remove the gas line where it atatches to the carb and insure a continuous flow of gas there the size of the lines inside diameter. IF NOT, remove the sediment bowl assembly and insure a flow of gas runs out the top lil holes to fill the glass bowl. IF NOT, there may be a restriction up inside the tank bottom or the inlet pipe. BOTTOM LINE, you have to have a continuous flow out the carb bowls lower drain cock as described above, before shes gonna run right. under load. ALSO, the carbs float level has to be set right so sufficint gas level is maintained in the bowl. ALSO, if the carbs top vent is plugged, air cant escape to allow gas to enter, and you wont get good flow into the bowl. CHECK AND CLEAN THAT TOP VENT BAFFLE. If you dont get good flow out the carbs bottom drain cock/plug, you may be able to clean the strainer by removing its side plug and cleaning it out OR remove the top cap and nut (may need new gasket) and clean it out OR remove the bowl and remove and clean out the needle valve and seat assembly. 7) If you have good fresh water free gas flow out the carbs drain cock per the above test,,,,,air cleaner bowl is clean,,,,, ,, a good hot blue spark on both plugs,,,,, ,,needles were adjusted and you tried richening (open out) them,,,,, ,,but she still requires choke, if she dont idle well, you may have a vacuum leak (sucked in air leans out mixture). To find that, at idle spray WD 40 or Carb Cleaner or an Unlit Propane Torch around the manifold base and the carb, especially the carbs top and bottom throttle shaft bushings. If she speeds up and smooths out, you found teh vacuum leak that leans the mixture requirign choke. 8) If you have a good idle but she sputters or dies out under load or needs choke at higher RPM's despite all the above and the float level is set right and you have a good spark and shes timed right, the main center brass vertical nozzle may be clogged. To clean it, you would have to remove the carbs bowl (dont loose lil spring) and drill and tap its bottom center bore if or as necessary to make a puller and extract the nozzle. DO NOT pry down on its center up inside the carbs bore, you might bend it. Once removed, clean and polish it and clean out all its lil side holes and check its interior. If she still needs choke either at idle or at high RPM or under load, post back and tell me what the tests above indicated. You can e mail me at [email protected] or post back or call me at (812) 824-4608 and I will try my best to help you out. Sorry if I missed something and hope its simple like needle adjustments or clean gas or clean and drain the sediment bowl maybe????? ?? God Bless you and all the fine JD Collectors and this boards contributors. John T Nordhoff in Indiana
