How much weight should a Deere M be able to pick u
Niner
09-14-2003 16:27:16
I recently got a 5ft box blade for my little JD M. It seems to work fine whilst attached to the 3pt.
My problem is loading or unloading it from the trailer / pickup using my boom pole.
According to the mfr., the box weighs about 500 pounds. I am sure that is multiplied somewhat when picked up at the end of the boom pole as opposed to the 3pt. The tractor will try to pick it up, but it just cannot get the whole box into the air.
I guess what I am asking is how much weight should an M be able to lift with a boom pole, and/or is there any way to beef-up the hydraulics?
Ralph Ia
09-14-2003 19:38:49
 Re: How much weight should a Deere M be able to pi in reply to Niner, 09-14-2003 16:27:16
Niner, in the operators manual it states, "A load of approximately 1120 pounds can be lifted at hitch point of drawbar.
Niner
09-15-2003 04:28:43
 Re: Re: How much weight should a Deere M be able t in reply to Ralph Ia, 09-14-2003 19:38:49
Yes, but what would that be at the end of a boom pole?
leon
09-15-2003 05:32:17
 Re: Re: Re: How much weight should a Deere M be ab in reply to Niner, 09-15-2003 04:28:43
Measure the distance from the lower link's pivot point on the tractor to the center of the hole on the outer end of the lower link. Then measure the distance from the lower link's pivot point on the tractor to the end of the boom pole and ratio it out. Lifting 500 pounds way back there sounds like expecting a lot of that little tractor!
