4320 boost and fuel pressure
Dave G
09-14-2003 16:07:42
How much boost pressure should a 4320 have? I was working it hard the other day and all it could pull was 7psi, and smoked black alot. Also, how much pressure should the fuel transfer (not injector) pump put out? Thanks.
Brokenwrench
09-15-2003 17:24:12
 Re: 4320 boost and fuel pressure in reply to Dave G, 09-14-2003 16:07:42
Air filter(s) dirty?
Dave G
09-15-2003 18:42:56
 Re: Re: 4320 boost and fuel pressure in reply to Brokenwrench, 09-15-2003 17:24:12
Already been through that, it was really sooted up. Before that it wouldn't even pull in third gear, now it does in fifth....thanks anyway!
JDBert
09-15-2003 08:07:36
Sounds to me like your turbos going bad. I would get it looked at before your impeller goes bad and sends parts through your motor or it wrecks the housing and you end up with a whole turbo to buy instead of just a rebuild.
twopop
09-14-2003 19:30:40
if i remember right,it should have 16 psi @2100 rpm
