2 JD pony motors, which is better
Les in Mi
09-14-2003 12:06:24
I have 2 pony motors and need to install one on my 70D. Both ponies are off, I have never heard either run. Before I intall one on the tractor, I'd like to hear both run to see which is better. Is there a way to run these without installing them on the tractor and having to hook everything up? This way I Know which runs better and/or does or doenst smoke?
Thanks, Les
Clooney
09-14-2003 13:26:23
 Re: 2 JD pony motors, which is better in reply to Les in Mi, 09-14-2003 12:06:24
Les, you can run it while off the tractor like Frank said. You really don't want to run it without water in it as the water pump can be damaged. Don't run either for long without adding a resistor to the 6 volt supply running to the distributor or you risk coil damage.
~You aren't going to learn much without putting a load on them so it might not be worth the aggravation. Both will probably smoke pretty bad until run under a load for a while so you won't learn much there.
~If I were trying to decide between the two I would run a preliminary compression test on both & just use the one that has the best compression. ~Once you have all the hood parts & everything else out of the way for a pony swap you can probably bolt the pony on the tractor for an actual under load cranking test faster than cobbling up a cooling system & mounting base. Once the sheetmetal is out of the way those pony's bolt on & off pretty quick.
~Franks suggestion to go through those ponies & do an overhaul could save costly repairs down the road & is probably your best [& possibly the cheapest] approach....
F-I-T
09-14-2003 12:31:56
Les:
If you supply gasoline (the tank must be up a little because it's gravity fed, but not so high as to overpower the carb float), and supply some cooling water from a garden hose (you'll probably never get it warmed up that way, though you might try to throttle the flow with a valve), you'll be able to hear them run. You can even install a common oil pressure gauge in place of the pipe plug on the front of the engine to see how the oil pump is performing.
You'll have to clamp 'em down, as they're heavy, but when all that mass gets turning, it will likely try to walk away from you.
Unfortunately, the clutch/transmission is where I have seen lots of wear that isn't apparent until you have them installed. I would check out the clutch brefore you install the one you choose, becuase it's such a pain to take them back off just to replce the facings and reset toggle gaps. There are only 2 or three bearings in the transmission and four rollers and springs in the overrunning clutch. Pretty cheap to replace while it's off. Then again, while the pony is on the bench, $40 for the rings, and $70 for the gasket set, and $50 tops for a valve grind gets your a top end overhaul, and the knowledge that the innards are okey dokey.
Good luck !
Frank-in-Tallahassee
70D // 855 // VAC
