4020 powershift park pawl 'drag'
todd wiscal
09-13-2003 18:21:36
hope some of you new generation experts can help me out. upon start-up and initial shift from park, tractor makes a noise which seems to be the park pawl 'ratcheting' against the gear for a few moments, then stops and tractor seems fine. service manual I recently picked up doesn't go into much detail on this but indicates one of a couple springs may be broken or weak. anyone have any knowledge of this? thanks in advance.
Mike wJ
09-13-2003 18:36:28
 Re: 4020 powershift park pawl 'drag' in reply to todd wiscal, 09-13-2003 18:21:36
I got a 3020 that does That once in a while when I take it out of park I hit the shift lever up against the shift Qaudrunt (not to hard )its caused in most cases from wear on a pin and some bushings in the shifter under the dash sometimes when we put ours in reverse it stays in neutral unless you bump the shift lever to the left in the reverse slot. ours has many many hours of loader work on it and has never been apart.
twopop
09-13-2003 19:55:31
 Re: Re: 4020 powershift park pawl 'drag' in reply to Mike wJ, 09-13-2003 18:36:28
check the spring on the pawl shaft,under the platform on the right side of the rear end housing.it could be broke or the cable may not move freely.
