3020 drawbar support
Shawn
09-13-2003 15:50:32
does anyone know how to get the little spring pin out on the pin that holds the front of the drawbar support? it's in a blind hole on the bottom side of the front hanger but don't look like it goes rite thru to the top side..is it a hardened spring pin or can you drill it out? the bushing in the front hanger on the drawbar support has gotten oblong and i wanted to replace it...thanks
Brokenwrench
09-13-2003 16:37:25
 Re: 3020 drawbar support in reply to Shawn, 09-13-2003 15:50:32
A big hammer and a heavy punch. Just drive the big pin out, shearing off the rollpin. Once the big pin is out you can use a small punch to knock out the small roll pin piece.
JDTECH
09-14-2003 16:44:02
 Re: Re: 3020 drawbar support in reply to Brokenwrench, 09-13-2003 16:37:25
The bushing you are refering to is made to have an oblong hole in it to allow for fore-aft movement. This allows for the load control shaft to flex when using draft control. However this bushing does get worn and need replacement. The proceedure for removal is the same as the previous posts advised. Good Luck!
Mike w J
09-13-2003 18:48:17
That roll pin just holds the bushing in it doesn't go threw the big pin . That big pin will drive out if you use a pin about the same size just a little smaller . if you don't use somthing about the same size when you hit it with a hammer your hammer will bounce and take twice as long
