6 Piston ring grooves only 5 rings in JD replaceme
Randy G
09-13-2003 14:15:45
I'm overhauling a 1955 JD 50. The pistons have 6 ring grooves and the new replacement rings have only 5 rings. Piston part Number is B3206R, replacement rings number is AB4958R. The top groove is narrower than all of them. JD dealer has no answer, nor does a friend that has worked on JD's for many years. I did notice in my 520's parts book the pistons show 6 grooves. The oil rings that came off the pistons were more than 1 piece like the 520's appear to be but the replacements I got were only 1 piece. PLEASE HELP ME SO I MAY CONTINUE!!! Thanks, Randy G
Clooney
09-14-2003 06:41:04
 Re: 6 Piston ring grooves only 5 rings in JD repla in reply to Randy G, 09-13-2003 14:15:45
Randy, those B3206R pistons are in fact Deere 50 pistons. As well as I can remember they are 5 ring pistons [I haven't done a 50 in a few years]..More than likely that top groove isn't a ring groove but is instead a carbon stopping groove. If it is narrower than the other grooves it is the carbon groove & doesn't get a ring.
~On the oil rings?..You can use either the oil ring with scrapers & expander or the conventional oil rings...
George S. in the real NY
09-14-2003 05:46:32
Here is a comment to your problem. I just did engine on 720 gas, and broke a ring. I did not really want to buy another set ($$$), so after some thought, I decided to leave some rings out. It now has 4 rings on each piston. It's days of hard work are over so here is my reasoning. The old bore was well worn. There was an oil ring at the bottom of the piston skirt as well as above the pin. I put the first oil ring above the pin so now the skirt can get more oil on it. I suspect all those rings were a left over from the days of all-fuel when it was acceptable to have oily fuel coming past the rings. With today's oil and fuels, I think it should do fine with 4 rings per piston. Also, you should find that there is almost no end gap with these rings so there is very little air leakage past the ring. I do not know if the ring width on your pistons are the same in all locations so you can make the change. A friend told me that Cummins did a similar thing with some engine years back.
Earl S.
09-13-2003 15:42:21
Do you have 6 grooves plus the top groove which is carbon groove??? How many rings did you take off???Are the pistons OE. Deere?? Earl
