310 D john deere backhoe 4x4 problems
kfarms
09-13-2003 12:12:13
stops pulling after it gets hot pulls fine while cold has burn three solenoids or relays in the dash that controls 4 wheel drive
please help
Jonathan
09-14-2003 16:59:15
 Re: 310 D john deere backhoe 4x4 problems in reply to kfarms, 09-13-2003 12:12:13
Stops driving in forward and reverse at the same time ?? or just forward???
kfarms
09-14-2003 20:13:52
 Re: Re: 310 D john deere backhoe 4x4 problems in reply to Jonathan, 09-14-2003 16:59:15
Both forward and reverse stops pulling. It acts like the chutches are slipping, but it only does it when the transmission gets hot.
jonathan
09-15-2003 14:36:30
 Re: Re: Re: 310 D john deere backhoe 4x4 proble in reply to kfarms , 09-14-2003 20:13:52
Does the oil smell burnt at all ?? does triggering one of the 2 disconnect switches make it drive again ?? ones on the shift lever..the other on the loadelever...
kfarms
09-15-2003 17:35:01
 Re: Re: Re: Re: 310 D john deere backhoe 4x4 pr in reply to jonathan, 09-15-2003 14:36:30
Sometimes you have to wiggle the button on the shifter but,it still pulls a little bit when it gets hot. It doesn't completely quit pulling it just looses its power in the transmission not the motor. We are thinking we need to put a rebuilt transmission in it.
Brokenwrench
09-13-2003 14:17:05
Check the wiring going to the 4wd solenoid, the switch,and the solenoid itself for a short. Any of these will cause the relays to fry. Also check the charge rate on the alternator for overcharging.
