Duplex Carb Video Tapes...Worth it?
Tye
09-13-2003 06:23:00
I am still having trouble with my fuel system on my 50. Some how I am still getting gas in the oil. I've had the carb rebuilt professionally and installed a new manual shut off valve. Someone told me that even though the carb was professionally rebuilt, there is still a chance that it could be the float and needle. So since I don't know much about carburators, are the videos that are offered on this site worth the purchase? Has anyone else purchased them with any luck? Thanks for any comments.
PatM
09-14-2003 11:28:57
 Re: Duplex Carb Video Tapes...Worth it? in reply to Tye, 09-13-2003 06:23:00
I own the carburetor videos produced by Robert's Carburetor Repair. They are very informative and show you exactly what you need to do to properly rebuild a carburetor.
David Bacon
09-13-2003 15:44:19
They are ok --probably worth the money, but the under tow is probably purchase materials from the creator of the video. I know I paid the Co. over $40.00 for one of their tools ---then bought another one in the same box and everything for less than $10.00. In the tapes there is alot of ---change this out---put this in new etc. If you do your own work you can minimize much of this cost. Most of us get so ticked off we will pay anything to have it done right, this is like owning RV's / boats / snowmobiles. The JD folks made a very complicated carburator compared to their competition at the time. They are actually fairly easy once you understand them. I simply got sick and tired of sending them off and paying good money for them only to be disapointed. I now rework my own as well as for many others with a 100% rate and a whole lot less expence.
IMDMAN
09-13-2003 15:15:44
I have not veiwed the carb videos but did buy a John Deere engine rebuild video for $24.95 + shipping. The 2 "goobers" in the video who did the rebuild should buy a few more tools besides a hammer and screwdriver. They were semi-informative but very ,very crude on proceedures and specifics.
Bus Driver
09-14-2003 14:42:42
 Re: Re: Duplex Carb Video Tapes...Worth it? in reply to IMDMAN, 09-13-2003 15:15:44
I agree about the engine rebuild video- but these fellows are not Roberts. Roberts is thorough and careful. He has good information.
BUDD
09-13-2003 14:43:58
What Dale said is true as it happen to a friend of mine. Oil in the gas at high RPM and gas in the oil at low RPM or maybe it is the other way around anyway we rebuilt it and the issue went away
Dale W.
09-13-2003 08:21:17
I cannot comment on the videos as I have never watched them, but there is one other item you need to check. Above your sediment bowl is a diaphram operated valve that only lets gas out of the tank if you have oil pressure. If this valve and diaphram malfunction you can get gasoline in your crankcase through the oil line that activates the diaphram. I hope this helps you solve your problem. Parts are available from Deere for these valves..... ..... .Dale
Tye
09-14-2003 06:14:20
 Re: Re: Duplex Carb Video Tapes...Worth it? in reply to Dale W., 09-13-2003 08:21:17
Dale,
The cut off system on my tractor is a manual cut off. I've checked the shut off valve and it doesn't leak at all. (It should I've replaced it 2 or 3 times in the last year) The only other thing I can think of is when I had the carb rebuilt the guy at the JD dealer didn't do some thing right putting it back together or the thing has some dirt in it. Thanks why I am contemplating buying a rebuild video.
