44 plow JDVan or anyone
murf
09-12-2003 19:57:48
JDVan just anote that 2 hours after I got my plow home I was out plowing and it worked great. I was surprised all the grease zerks took grease and the adjust crank loosed up with a half hour of soaking. My next question is there a procedure or product other than 2 days of plowing sand to scour the bottoms they are pitted and rusted.
Mark
09-13-2003 12:34:55
 Re: 44 plow JDVan or anyone in reply to murf, 09-12-2003 19:57:48
I use muriatic acid brushed on the bottom after wire brushing with a grinder, allow it to sit a few hours and then plow, will clean right up.
MIKE HANLEY
09-12-2003 21:14:15
You could try a wire brush head on a heavy duty hand grinder (MILWAUKEE or alike). And or some product with NAVEL JELLY as it's main ingreadenent. Once cleaned up there is a black paint that JD sells special for moldboards and disc blades, etc, that will scour right off when the implament is used. You have to do this each time the implament is layed up. In the old days guys used to schmer grease on the moldboards, but after sitting out side for a year, the graese was sometimes just as hard to get off as if it was rusted. I use the wire brush, and NAVEL JELLY on most things that I'm going to paint. I also use GUNK degreaser and Brake Clean alot to claen things up.
JDVan
09-12-2003 21:12:10
If they are pitted badly there isn't much you can do but replace the moldbaords. To clean them up I take a right angle grinder with a heavy twisted wire brush and clean as much of the rust off. Then plowing in real life it the only remaining solution.
