Compression tests-JD early GP Std-advice requested
David Beaty
09-12-2003 18:03:43
We are considering whether or not to overhaul the engine on the old GP prior to restoration. Measured 50 psi on the Left and 65 psi on Right cyl. The tractor is running and has never had any overhaul work done. We are getting ready to put in new seals and put a really nice paint job on it for shows and demonstrations. It hasn't been run hard for many years so I don't know how much it smokes after it gets hot, or oil usage under load as radiator leaks badly and will have to be replaced during rework, so I can't load it up and work it hard right now. What would you folks suggest be done for engine work while it is in tear-down for primer? Or what checks would you make on the engine in this condition (my first restoration in-process)..... Any thoughts or advice would be much appreciated.
_____ _____ _____
Any and all assistance and/or advice is greatly appreciated
Brokenwrench
09-12-2003 18:17:43
 Re: Compression tests-JD early GP Std-advice reque in reply to David Beaty, 09-12-2003 18:03:43
If it was mine, I would tear it down and at least put in a set of rings(if the bores are still marginally in spec.) and have the head done and check and set the bearings.If you spend the time and money painting it, and then find out that the blow-by is pushing oil out of all the seals on your new paint, you will end up doing it anyway,plus a lot of touch up work.JMHO
F-I-T
09-13-2003 15:02:03
 Re: Re: Compression tests-JD early GP Std-advice r in reply to Brokenwrench, 09-12-2003 18:17:43
Well, I sure agree that a set of rings is never a bad thing. A fresh cylinder honing and a valve grind, for the money, really gets an engine a lot closer to fresh than wondering about it. Unfortunately, there's not much to do on the head, since it's a valve in block engine. About all you can do is have it checked for flatness and corrected if it's warped. In the old days, they had long arbors and cutters and could cut the seats with the block in the tractor. But it's unlikely you 'll find anyone who can do that for you today, so, if you want to do a correct valve job, you'll probably have to pull the block. Then check and at minimum, set the rod and main bearings if they're still servicable.
Then you'll know what you have.
Frank
