JD 2150 (1983) Diesel
Doug Marley
09-11-2003 17:49:56
Overheating: Water pump overhauled, radiator reworked about three years ago and a new thermostat was installed. Still, tractor overheats. With the thermostat removed, there is good water movement. With thermostat in, engine overheats but water is still cool in the radiator. Any idea?????
david val
09-11-2003 23:13:37
 Re: JD 2150 (1983) Diesel in reply to Doug Marley, 09-11-2003 17:49:56
check temp with a themometer inserted in the radiator filler neck. work tractor until worm and thermostat is open and compare thermometer reading with tractor gauge. could very wll be a gauge or a sensor problem.
david
