3020 gas not charging
Shawn
09-11-2003 14:43:25
I have a 1965 3020 gas,the generator won't charge (gen lite is on all the time).i checked with meter and i get flickering voltage readings anywhere from 0 to 13 volts.I checked it at the battery and have 12.46 volts when tractor is not running.Start it and it jumps around from 0-13 volts there as well shut it down and reads 12.46 volts again. run tractor for couple of days and the battery is down and needs charging. we took the gen and voltage regulator to our starter/generator guy and he set it all up said it was working good took it back home and put back on the tractor and it's still doing the same thing....HELP!!. i assume the regulator is suppose to be grounded to the tractor.where do i go from here?
S. Conner
09-11-2003 23:03:06
 Re: 3020 gas not charging in reply to Shawn, 09-11-2003 14:43:25
Have you polarized the voltage regulator?
Jailkeeper
09-11-2003 19:59:56
Sounds like you have a ground problem. Make sure the regulator is grounded good, as well as the battery cable grounds.
You might want to pull the platform off and check the crossover cables, sometimes they will get holes rubbed in the insulation and corrosion forms causing all kinds of weird problems.
