DLTX 10 economizer plugs
buckeye al
01-19-2004 15:11:50
Working on a DLTX 10 from a B for a coworker. I've read through the archives re-economizer plugs & looking at my data sheets I see that the DLTX 10's used either a D or an E economizer plug. This one has a D in it but it is severely wounded and should be replaced! I don't have data sheets that tell me if the D or the E is the larger plug & which might therefore be the best choice for this parade tractor likely to burn only gasoline. Would appreciate suggestions and information on your experiences.
Thanks.
buckeye al
01-20-2004 15:11:13
 Re: DLTX 10 economizer plugs in reply to buckeye al, 01-19-2004 15:11:50
All questions answered!
Thanks fellers!
Clooney
01-20-2004 08:53:49
Al, the D seemed to be used on the early DLTX 10 carbs & the E seemed to be used more on the later DLTX 10.. I doubt you will be able to tell the difference between the two..
~The smaller the economizer plug the leaner it will run in the mid range under light load due to more back suction... It's more of an economy issue than a runability issue. In theory you want less back suction with the heavier fuels but I can't tell much difference between the plug sizes when running on gasoline. A little tweak on the idle & load screws & the slight difference is made up.. The 2-cylinder gasoline carbs used a fixed economizer orifice so Deere didn�t think it was worth the effort to make it adjustable� The different sizes were more for metering control on the heavier distillate fuels.
~The load nozzles are different story as those can make a big difference with just a slight change..
~If you are looking for an economizer plug recommendation give Robert�s Carb a call Phone.. (712) 262-5311.. I�m sure has run tests on all of them & can give you the information you seek..
[email protected]
Earl S.
01-19-2004 16:24:18
"D" .1685 "E" .171
