2 bolts going into crank shaft housing - purpose??
James Kruse
09-11-2003 10:26:43
I have a 1947 John Deere A and I just got it tuned up and it is running fine but there are two bolts that go into the crank shaft housing that are rattling or moving and I don't know what they are attached to or thier purpose. They are located in front of the governor and distributor. If anyone can please tell me thier purpose I would appreciate it. Thanks.
MikeM
09-11-2003 12:01:17
 Re: 2 bolts going into crank shaft housing - purpo in reply to James Kruse, 09-11-2003 10:26:43
Probably the ones that hold the cam follower assembly in place. There is also one more inside the governor housing that you can't see that should also be tightened.
James Kruse
09-11-2003 14:28:48
 Re: Re: 2 bolts going into crank shaft housing - p in reply to MikeM, 09-11-2003 12:01:17
Thanks for your reply. One more question.
They move up and down about 1/2 to 3/4 of an inch with the engine revolutions. How do I go about tighening them??
MikeM
09-12-2003 05:49:19
 Re: Re: Re: 2 bolts going into crank shaft housing in reply to James Kruse, 09-11-2003 14:28:48
they should just tighten up if they don't you got big troubles as these tread right into the follower casting.
Clooney
09-11-2003 11:05:07
James, are they running vertical down from the top? Or in the side? What size heads do they have?
James Kruse
09-11-2003 14:26:24
 Re: Re: 2 bolts going into crank shaft housing - p in reply to Clooney , 09-11-2003 11:05:07
running vertical from the top with 1/2" bolts. I think it holds cam follower assembly.
Thanks for replying.
