2-14 plow ID
murf
09-11-2003 10:16:21
I bought a 2-14 plow some one said it was a model 44H and it looks just like the one in implements photos on this site. There is a partial decal on the front beam that appears to read ---6S it has hyd lift and a crank for adjustment. Is there another model in this size plow? I can get more numbers off it tomorrow when I pick it up but I was just curious before I bought a manual for it.
murf
09-12-2003 10:37:11
 Re: 2-14 plow ID in reply to murf, 09-11-2003 10:16:21
Mystery solved. When I picked it up the farmer came out with the manual. It is a 44H but a later model with a hand crank instead of a lever. Now to find out if I can get new lathes for it. Thanks for all your help.
Bob Collins
09-12-2003 19:18:37
 Re: Re: 2-14 plow ID in reply to murf, 09-12-2003 10:37:11
Murf, If it has a crank it is the EARLIER version, after 1948 the crank was changed to a lever. By the way, the 44H (and 44)has a fixed rear wheel and transports on 2 wheels, a 44AH (and 44A)has a rear wheel that "steers" and transports on all three wheels. These (44A and 44AH) seem to be scarce everywhere I have looked. bob
JDVan
09-11-2003 16:55:54
Does it look like the plows at this loaction?
Link
murf
09-11-2003 20:37:06
 Re: Re: 2-14 plow ID in reply to JDVan, 09-11-2003 16:55:54
Thanks for the reference photos. On the hyd. models would the leveling lever be replaced with a hand crank?
DaveH 50
09-12-2003 05:21:23
 Re: Re: Re: 2-14 plow ID in reply to murf, 09-11-2003 20:37:06
The model 44 rope trip plows use two levers as in the photos. The hydraulic lift 44H and 44AH plows use either one lever or one crank. I'm not sure if the crank was an option or if it replaced the lever at a certain model year. I have a sales brochere dated June 1950 and it shows only the lever. I have a 44H with the crank and have often wondered why the crank - maybe it's a later production change?
Dave
Bob Collins
09-12-2003 19:12:19
 Re: Re: Re: Re: 2-14 plow ID in reply to DaveH 50, 09-12-2003 05:21:23
The 44H and 44AH plows came with a crank for leveling until 1948 when it was changed to a lever.
jdvan
09-11-2003 20:45:40
I'm not sure about that but I don't think so. I only have a trip version here.
murf
09-11-2003 22:08:01
 Re: Re: Re: Re: 2-14 plow ID in reply to jdvan, 09-11-2003 20:45:40
I'll post some casting no.s tomorrow when I get it home
