G chokes down when increasing throttle
JD-G
09-11-2003 07:20:22
I went ahead and took off my distributor w/ electronic ignition since the G was backfiring and trying to kick the flywheel backwards against starter when cranking. I tried to time it, but still couldn't get it to run correctly. So now I've got the mag back on it and adjusted it where it's running alot better. However, now whenever I give it more throttle it acts like it's choking. Do I need to adjust the load and idle needles on the carb or something else? If so, once again how do I go about doing this?
JD-G
09-12-2003 07:29:39
 Re: G chokes down when increasing throttle in reply to JD-G, 09-11-2003 07:20:22
Thanks again Clooney and John T. I can always count on you guys to come through with good information. I'll take the carb off and check the choke plate, and needle. I believe my oil bath cleaner is ok since I soaked it in diesel before reassembly and it has fresh oil in it. I'll double check though.
Clooney
09-12-2003 09:32:57
 Re: Re: G chokes down when increasing throttle in reply to JD-G, 09-12-2003 07:29:39
JD-G, it's probably something simple. Let us know how it works out. ~Any other info needed just post back or E-Mail..
[email protected]
John T
09-12-2003 08:57:31
Youre sure welcome G Guy, glad we could help. If it dont work, I volunteer my friend clooney to come there personally and fix it lol.. John T
Clooney (additional info)
09-12-2003 06:39:33
JD-G, I just had a thought on my way to work this morning [my wife claims that could be dangerous]. I usually just dump the first page of YT onto my laptop & work on them during my drive to work.
~If you have the big carb on that G tractor make sure the tapered [angled] end on the load nozzle is DOWN].... If it's facing up your load metering will be way out of kilter...
~There is some posted data on this site that refers to it pointing up but that is incorrect...
[email protected]
John T
09-11-2003 20:31:09
Hey there G guy, If shes choking when you open the throttle, the first thing I would do is remove the air inlet pipe from the carb and insure the choke plate is tight on its shaft and especially that it closes and opens AND STAYS OPEN in relation to where you set the external choke rod. If the butterfly plate is loose on its shaft or its loose and free to go where it pleases, regardless and independant of where its set externally, it may indeed be choking down.
Also insure the air inlet pipe is clear of obstructions and likewise, the air cleaners lower bowl is unobstructed and clean.
Is the float level set to where it shuts off the fuel at approximately level???
Try to adjust the load needle and see what happens, the initial rough in settign is closed down then back out 3/4 to 1 turn. You may be running too rich?????
You can e mail me at [email protected] or call me at (812) 824-4608 with any more questions.
Good Luck and God Bless
John T Nordhoff in Indiana
Clooney
09-11-2003 18:33:25
JD-G, you say...."now whenever I give it more throttle it acts like it's choking"..////..Maybe it is, pull the air inlet off & make sure the choke plate isn't bent & that the choke plate is opening all the way.
~You can try a carb adjustment to see if that helps. Start with the load needle at 1 turn out from seated & the idle needle at 2 turns out from seated..
~While the air inlet is off to check the choke, run the tractor to see if maybe you have a restricted air cleaner.
~Where is you base & running timing set now that you put the mag back on? If you are running late timing it will act rich under load...
