Compression inserts for MC Crawler
Dominic Centonz
09-11-2003 07:16:33
Is there a such thing as compression inserts for a MC crawler? If so, where can I obtain them?
Clooney
09-11-2003 11:13:48
 Re: Compression inserts for MC Crawler in reply to Dominic Centonze, 09-11-2003 07:16:33
Dominic, I've never seen compression donuts used in the M or MC. You don't want to over do the compression in those early Dubuque�s as they are marginal for overheating to begin with.
~I'm not sure how you could even hold a compression donut in a Dubuque as the cylinder bores are straight & the head is close to the piston...
~I did see an M about 20 years ago that had �� steel plates bolted to the tops of the pistons.. It seemed to run ok like that�
