2240 hydraulics
Pete/ME
09-11-2003 03:41:50
Started working a Valby chipper on my 2240. After about an hour of steady work the bucket and lift arms quit working, (the chipper seems to work O.K.) let it sit for about 10 min. and they slowly start to work again. Chipper is piped direct to system (not remotes) and has a closed center valve. Hoses and valve seem pretty hot. Am I asking too much from the tractor?
Pete/ME
09-12-2003 03:45:45
 Re: 2240 hydraulics in reply to Pete/ME, 09-11-2003 03:41:50
Its to the barn to find out 1) where and what the "priority" valve is, and where my aux. line is plumbed to, and 2)to figure out if I have a "live PTO" or a "live independent" PTO. (when I disengage the PTO, the flywheel on the chipper spins for about five minutes). Thanks very much for all your help.
david val
09-12-2003 06:51:24
 Re: Re: 2240 hydraulics in reply to Pete/ME, 09-12-2003 03:45:45
if your tractor has power steering (sorry,took it for granted), then it has a priotity valve. the priority valve is attached to the right side of the transmission under the footrest at the rear end of the pressure pipe (a 5/8 pipe passing with others at the right side of the engine with a T leading to the steering valve). if the pressure line to the chipper is plumbed along this line, then a problem that you describe may develope.
if there's no power steering disregard this post.
heating the oil is expected when working with a hydro motor.
david
Pete/ME
09-14-2003 03:51:53
 Re: Re: Re: 2240 hydraulics in reply to david val, 09-12-2003 06:51:24
Yes, it does have P.S., and that's where the aux. remotes are piped. Even before I hooked up the chipper the P.S. does sounded squeaky after a few hours but still worked. The tractor has a #145 loader. Where else should I plumb the remotes? (By remotes I don't mean the quick disconnects stock with the tractor which I don't use for the chipper or other.)Thanks.
david val
09-14-2003 04:17:44
 Re: Re: Re: Re: 2240 hydraulics in reply to Pete/ME, 09-14-2003 03:51:53
the most logical place will be the tratcor's coupler operated by the scv for pressure and the filter ported cover for return.
david
Pete/ME
09-14-2003 09:34:51
 Re: Re: Re: Re: Re: 2240 hydraulics in reply to david val, 09-14-2003 04:17:44
Sorry...scv?
david val
09-14-2003 10:52:16
 Re: Re: Re: Re: Re: Re: 2240 hydraulics in reply to Pete/ME, 09-14-2003 09:34:51
Selective Control Valve, the valve that controls oil flow to the remotes.
david
John
09-12-2003 04:02:01
Two stage clutch means your basic clutch pedal must go all the way to the floor engage your pto shaft. That will make you pto spin as your foot is raised. Then the tractor will move ( if in gear) when the second stage is reached. Live independent has a pto engagement lever or knob between the two gear shifting sticks. It will work ( on or off)whether the tractor is in gear or not and completely independent of the tractors regular drive clutch.
david val
09-11-2003 11:04:24
sorry, i don't know what a valby chipper is. from the post i assume the hydraulics run a hydro motor(?). if so, make sure the presssure line is plumbed behind the priority valve. if plumbed ahead of the valve, pressure reduction (to, if i remember well, below about 1800 psi), will cause priority valve to block or reduce flow to rockshaft and remotes.
david
John
09-11-2003 03:58:10
Compare your hydraulic oil when the tractor gets hot and the symptoms occur vs. when its cold. I suspect you will find tiny air bubbles homogenized in the oil. Use a magnifying glass. Could be caused by asking to much or an improperly routed oil return line. Make sure it returns the oil to the Hydraulic filter cover, not just dumping the oil back into the reservior. Other issues like a worn PTO brake/clutch may contribute. Use of a PTO overunning clutch may be prudent here. Maybe Davidval will post with more/better insight to help you
Pete/ME
09-11-2003 06:25:09
 Re: Re: 2240 hydraulics in reply to John, 09-11-2003 03:58:10
Thanks John. Does oil "wear out"?, and how do you tell? Return is to oil filter case, and as far as the PTO brake/clutch...the machine although a 2240, has only 800 hrs. Don't know how an overunning clutch would help, as the tractor has a live PTO. Will check the oil for bubbles.
John
09-11-2003 16:05:59
 Re: Re: Re: 2240 hydraulics in reply to Pete/ME, 09-11-2003 06:25:09
I assumed your tractor was equiped with a "live independent" PTO. Sorry. As long as you have "live PTO" (two stage clutch), not "live independent" you wont need the overunning clutch. With live independent the PTO brake is automatically applied when the PTO is disengaged. Tools with momentum like chippers and brush hogs will fight the brake wearing it out prematurely and causing oil to bypass the PTO brake. This causes "Funky Hydraulics". Use of the overunning clutch prevents this. I learned this the hard way using a PTO chipper on my 2840. The flywheel cutters momentum wiped out my pto brake in short order and gave me various kinds of hydraulic problems.
Pete/ME
09-14-2003 03:44:40
 Re: Re: Re: Re: 2240 hydraulics in reply to John, 09-11-2003 16:05:59
John-I do indeed have a "live independent" PTO...lever on side of transmission, and yellow pull handle between shifters. Power steering has always sounded squeaky after running the tractor a few hours (seems to work O.K.) I've run the chipper a total of six hrs., but think the problem was there to begin with. A new hydro. pump was installed two years ago, where would be a good place to look to fix it. (Mean time I'll use an over-running clutch. (Thanks)
