JD 50 transmission damage - repair or replace?
Bruce L
09-10-2003 21:14:21
third party image
The countershaft in my JD 50 transmission has damage to the bearing journals, primarily due to corrosion. This also effected the idler gear that rotates around this shaft. The needle bearings are shot of course. I sure wish they wouldn't have designed these parts so that the bearing runs directly on an expensive part to replace. To repair this, I suppose it would have to be ground down, and then hard chromed up to oversize, and re-ground to size again. Or could it just simply be welded up and then ground to size? As bad as it looks, this transmission before tear down did not exhibit any obvious sign of problems. I opened it up to repair the PTO disengagement mechanism.
ChuckW
09-11-2003 05:18:41
 Re: JD 50 transmission damage - repair or replace? in reply to Bruce L, 09-10-2003 21:14:21
not unusual for a 50 plus year old tractor...what has happened is crude and probably no one ever changed the transmission oil, had moisture build up. Just find another good shaft...try 2 cylinder parts....David Marlin.
