70 tractor power-trol
Tom Kelley
09-10-2003 19:10:02
Several years ago I was I was pulling a dump wagon loaded with firewood. The tractor, a 1954 model 70 gasoline had spent the night in the barn but the loaded wagon had sat in the woods all night with temperatures reaching 15 degrees.
So I pulled the wagon into our barnyard and pulled the power trol lever to dump the wood. Nothing happened for a few seconds and then I heard a pop. Then nothing continued to happen.
I'm figuring that the hydraulic line to the wagon had frozen and when I tried to raise the bed, something in the tractor snapped.
Here is the situation today, the lift arms lower and raise even with the metering valve seated. A small amount of oil is discharged from the coupling in the raised position and oil runs out freely in the lower position. There is no pressure in either position and no discharge when the lever is in neutral.
Any advice?
Clooney
09-11-2003 05:51:11
 Re: 70 tractor power-trol in reply to Tom Kelley, 09-10-2003 19:10:02
Tom, we need a little more information...How are you plumbing the remote cylinder? Are you using the rear P/T adapter fittings or are you using Pioneer quick disconnects from the P/T side ports?
~You say the lift arms are raising & lowering? Is that on the wagon or the tractor rock shaft?
~Your problems could be different depending on what arms you are talking about & where you are plumbed into...
