37 B idles slow now, but how can I get even slower
David
09-10-2003 18:27:18
Bought the magic pair of aircraft drills from Roberts in Iowa and cleaned out all the idle passages in the carb and put in new brass plugs too. Now it idles nice and slow, but how can I get it even slower? Probably need advice on fine timing magneto or something. Any ideas appreciated.
Clooney
09-11-2003 06:23:05
 Re: 37 B idles slow now, but how can I get even sl in reply to David, 09-10-2003 18:27:18
David, I totally agree with Earl's carb set up procedure. That throttle plate must seal tightly almost all the way around to get the lowest idle speed. Pay particular attention to the throttle plate ends as any air getting by there will really effect the idle quality. The throttle plate must fit the worn throttle bore & not just be new & round. ~On your mag, that is a problem in itself. The problem with a mag is you only have two advance positions [FULL] & [NONE]. To get the best idle you need about 5� per 100 engine RPM. Your mag gives you 0� at under approximately 250 RPM & then goes abruptly to 25�+ at over about 250 engine RPM. A distributor would be your best bet as the advance comes in slowly as the RPM is increased. You can work with a mag & get some of the advance traits you need but will have to pay a penalty elsewhere. If you are using the Wico X [XH] mag you can install the later impulse spring & center spool & the get an additional wind up on the impulse spring, that takes the spring windup out of the mag at low RPM�s & gives you a much more consistent running timing. If you can get the engine to run below 250 RPM�s [pretty easy on the Deere�s] you can limit the total advance then add a little more base lag timing. A lot depends on if you just want the lowest idle you can get or want it to do anything at that low RPM.
~If you get the engine idle down so you hear the mag click you can try loosening the mag bolts & playing with the base setting to see if you can find an improvement.
~Depending on your mag�s power [spark] output you will probably find a gain by opening up the spark plug gap to .040�+ [.045� if you can fire that gap].
~Another place to work with is engine friction. Thin engine oil will allow the RPM�s to come down real low without the friction loss of heavier oil. If you are using the clutch engaged for added mass at low idle a thin oil will also improve the 1st reduction gear area friction. If you are runing high oil pressure re-set that so it is a little lower.
~The carb will also probably start to go rich as the idle speed gets lower so you will have to tweak the idle mixture needle setting as the speed comes down.
[email protected]
John T
09-10-2003 20:36:39
Hi David, I have an unstyled B also and love that sweet slow idle, but Ive never had as good luck gettign a B to idle quite as slow as an A or G with a heavier flywheel. Also, extended idle periods are hard on the tractor as the cylinders and valve assembly dont get the oil they should.
To get a slow idle, some things needed, in addition to an otherwise well tuned carb and ignition, are as follows:
1) There can be no vacuum leaks, like around the throttle shaft bushings, top or bottom, or any other places like the gasket etc.
2) The throttle butterfly plate has to be round and concentric and match evenly with the carbs bore.
3) The throttle shaft bushings have to be insertd all the way deep down towards the bore center just to where they dont interfere with throttle plate movement.
4) The throttle stop spring and the screw adjustment to it have to be where the spring has some pressure exerted against it by the stop screw.
5) The ignition has to produce a good hot blue spark and be in time. I prefer Autolite 3077, the side wire electrode type plugs.
6) The throttle rod from the governor to the carbs top has to be properly adjusted. 1/2 hole from reachign the carb at WOT. 7) Slowlyyyyy y at slow idle tweak the idle needle in.
Remember, at around 250 RPM and less, the mags wind and trip srping assembly will start clattering and working.
Good Luck n God Bless
John T
Earl S.
09-10-2003 19:29:25
The carbs. I rebuild you have to pay close attention to the throttle plate area. When your carb was brand new the bushings were installed and the the throat was bored perfectly round. If the bushing on the throttle shaft have been replaced and not reshaped to the bore you will have a gap at top and btm and the throttle plate will need to be replaced if it is worn.It will pull air past the plate but not a good fuel air mixture. When the throttle plate is closed it should be between 2 holes on the side of the throat.Slide the plate as close to that side as possible but not drag.Hold the carb up to a light with the plate closed and make sure it fits the bore.If the 2 side holes on the throat have been enlarged it may not run as slow as you like.Let us know what you find.If your mag is good the impulse comes in around 250 rpm It should idle clear down until the impules starts clicking.But the engine itself has to be in top condition with good compression.Earl in Illinois
