Good Evening David, The surging you describe could be a carb or governor or another problem and heres how I would proceed. Its often caused by plugged idle passages in the carb if adjustign the needles dont help. Try adjusitng them and see if slight choking helps or if governor linkage rod length adjustment (see below) helps first????? ?? Also, be sure she has clean fresh water free gas and the plugs are not partly fouled. If the plugs appear fouled or all blackened or oily, try a fresh set. 1) Remove the throttle linkage from the carbs top and if you manually hold the throttle plate in position, will she idle down smooth then or start to die out at slow idle????? ?? 2) If you can manually (no governor in the equation) get her to run and idle smooth, there may be a governor or adjustment problem. At WOT with the linkage rod from governor to carb removed, the rod length should be about 1/2 hole short of reaching the carbs drop in hole. 3) If operated manually she dies out at slow idle and adjusting the idle needle dont help, there could be a plugged idle circuit in the carb (a common bad idle problem causign RPM surging). If an idle passage is plugged, the surging is cuz the governor opens to speed her up, but then when it starts to idle down it starts to die, so the governor opens back up, and that cycle repeats causign the surging. At higher RPM where the governor kicks her up to, the carbs load circuit works and takes over and she runs okay there, but at idle with the passages plugged, she starts to die causing the governor to surge the RPM upwards. Have you tried to adjust the carb tops idle needle out a tad richer and see if that helps????? The initial rough in settign is closed then back out 1 3/4 to 2 turns. If shes choked a bit, will she idle down then and stop surging????? Other causes of poor idle are vacuum leaks especially around the throttle shaft bushings or intake gasket or manifold. If you spray WD 40 or Carb Cleaner or an unlit propane torch around those areas and she speeds up, youve found ur vacuum leak. Other poor idle problems may be due to the throttle plate not being round and concentric to the carbs bore. If adjusting the needle dont help and your ignition is good and shes timed and still surges and wont idle down smoothly even manually (with governor disconnected) theres a good chance one of the internal idle passages is clogged. They usually will not come clean even if you soak and boil the carb till the cows come home. Usually you have to remove the brass drill plugs (see link below) using heat if necessary, then drill the idle passages behind them using the extra long aircraft type No 40 and 53 Drill Bits, and clean the smaller passages with steel guitar strings or weldng wire etc. Dont drill the passages too deep and use the bits ONLY on the passages shown with the size bit shown at the Roberts Carb Repair web page link below Link
