Experiences with Taper-Loc Flywheels
PatM
09-10-2003 17:31:20
I have a 730 Diesel that I am thinking about installing a taper-loc flywheel on. I would perfer to install a good used one but a couple of people have started to talk me into a taper-loc. Was wondering if anyone could share thier experiences, good or bad, with me.
Ty
09-12-2003 13:00:37
 Re: Experiences with Taper-Loc Flywheels in reply to PatM, 09-10-2003 17:31:20
They're great! Mine is a old flywheel grinded down for the taper lock and you don't have to shim the cover.
PatM
09-11-2003 16:46:38
Thanks for your input. I have pretty much decided that I'm going to use a taper-loc flywheel in lieu of a good original. Bo, I too have also heard that sometimes when using the taper-loc flywheel that the flywheel cover has to be shimmed out. That was one of my concerns but the fellow I'm talking to assures me that the flywheel they sell will not require shimming the flywheel cover. The taper-loc I am looking at is a complete new flywheel with the taper-loc feature. I have heard that they also make taper-loc flywheels out of old original flywheels by machining out the center splines and installing the tapered hub. Perhaps these are the ones which require shimming of the flywheel cover.
Bob In BUF
09-11-2003 13:01:04
I have a JD 70 Gas that had a bad flywheel when I purchased it. I tried a good used flywheel. Put it on, it seemed great, one hour later it was wobbling aroung like the other one. I bought a Taper-Loc, And I couldn't be happier!!! My splines were pretty well worn, but the Taper-loc works perfect. Just make sure you tighten it from time to time, and you'll be fine.
MikeM
09-11-2003 07:58:53
I have seen good results with the taper loc flywheels. I would also buy the flywheel made new
for use with the taper loc feature they have a heavy built center web with no holes not as prone to cracking. Just make sure you use a big hammer
hit it once on web then tighten with a big wrench and repeat til it won't go anymore.then recheck it after working the tractor every so often.I had one go on too far once and had to shim it out with big machinery washer to get it out of ring gear.
Bo in Maryland
09-11-2003 06:47:30
.....I just went over this with my mechanic....he cautioned that sometimes the taper-lock doesn't fit right and the flywheel cover has to be shimmed up to give clearance....so then I called Allen machine works down in Tennessee and asked them....they said that sometimes their taper-locks have to be "machined-out" to fit under the fly wheel cover....good luck, whatever you decide....
Bo
MIKE HANLEY
09-10-2003 22:25:53
We have one on one of our 730D's and have had no problems. It gets "bumped on with a 16# maul. If you need to remove it you "bump it off" againg with a 16# maul. Once the splines start wearing on the the crank and flywheel, it does not get any better. If the splings on the other 730D start to wear, I'd put one on that one also.
MIKE HANLEY
09-10-2003 22:35:17
 Re: Re: Experiences with Taper-Loc Flywheels in reply to MIKE HANLEY, 09-10-2003 22:25:53
Never just shut off the fuel on a diesel. Also step on the decompression lever. It's the rocking back and forth of the flywheel on the last pop that starts the wear on the splins. And once the splines start to go the only way to fix it rigth is to put in a new crank and a new flywheel of go to the lock tite. The one we have it on has about 1200 hrs on the overhaul and the lock tite.
Larry806
09-10-2003 20:09:08
My experince has been bad! 720 70D & 730 none have worked out at all. Neighbors have put them on none, will stay put The dealer say's drill & tap the end of the crank to 3/4 in install a big washer to hold it from walking off
buickanddeere
09-12-2003 19:51:09
 Re: Re: Experiences with Taper-Loc Flywheels in reply to Larry806, 09-10-2003 20:09:08
Those taper-loc flywheels which are properly installed work just fine. I can't believe your dealer would suggest the old "bolt in the end of the crank" trick. The liability incase there was a total failure as the loose flywheel rattled on worn splines is beyond considering.
