70 diesel having trouble getting governer lever ho
David hunt
09-10-2003 16:29:38
Help!!! i cant get the speed control on my 70 diesel to move the rack at all.I have made double and triple sure im getting the lever on the govener lever housing into the slot inside but it will not move when you move the throttle. i have tore into the govener to make sure the thrust bearing and sleeve was free in operation and everything looks good. i have tried adjusting the eccentric bushing on the govener lever housing also but it just wont move the rack at all and the rack all moves freely. please help..when i parked the tractor all this worked but i put new rings and re conditoined the head and now im having problems with this. thanx for ANY info. David
PatM
09-10-2003 18:09:31
 Re: 70 diesel having trouble getting governer leve in reply to David hunt, 09-10-2003 16:29:38
I don't know for sure without looking in the parts manual if the 70's had it, but on the 720/730's there is a pin that is about 5/16" in diameter that slides in and out of the block and transfers the movement of the govenor arm to the injector rack. Are you sure that the pin is in place and not binding?
David hunt
09-10-2003 18:24:09
 Re: Re: 70 diesel having trouble getting governer in reply to PatM, 09-10-2003 18:09:31
Hello pat, yes im sure the pump control rod is free and not binding.I can push it in very easy with my finger and the spring pushes it right back.Im stumped bad on this problem.
