Could kerosene replace Stabil as a winter adative?
Ravgardner
09-10-2003 11:21:06
I just finished reading the thread on adding kerosene to gas. I've been very curious about doing an experiment myself, but what I am wondering now is, would the kerosene be a good winter storage gas additive? Could it replace Stabil as a winter storage additive. What do you think?
buickanddeere
09-10-2003 14:18:10
 Re: Could kerosene replace Stabil as a winter adat in reply to Ravgardner, 09-10-2003 11:21:06
JP8 or JetA-1 is even better than kerosene for storage.
Clooney
09-10-2003 11:40:46
Ravgardner, not as an additive, but by itself kerosene stores pretty good. I use kerosene as a storage fluid in some of my old tractors that don't get used very much. It doesn't seem to turn to that thick sticky tank eating varnish that ruins fuel tanks & rusts up carburetors like gasoline does. I don't like to drain the tanks dry as the cast iron carbs rust up inside & the valve packings dry out & the tanks rust inside without fluid. I usually add some 2-cycle oil to the kerosene for storage anti-rust. Short term I use Stabil in the gasoline & longer term I use mineral spirits with oil mixed in. I have some tractors that haven't been started in about 3 years & I don't see a rust of gum formation in the fuel tank yet. I probably won't go much longer before replacing it though..
tom
09-10-2003 12:52:40
 Re: Re: Could kerosene replace Stabil as a winter in reply to Clooney , 09-10-2003 11:40:46
Clooney,
I recently acid-washed and thoroughly cleaned the inside of my gas tank on the MT...then I used a commercial gas tank liner I purchased from Sharp's Antique Tractor. The liner directions recommended applying it two times, with an hour interval bewteen app's., then 24 hour drying.
I can not recall the primary chemicals in the liner, but if it hit your skin, your skin turned black. Will this type of liner prevent the gas-tank rusting and/or corrosion you alluded to in answering the gas/kerosine question?
I applied some of the liner to a cedar board and the stuff dries clear & hard...just curious on any preventative measures.
thanks,
tom
Bus Driver
09-10-2003 16:54:50
 Re: Re: Re: Could kerosene replace Stabil as a win in reply to tom, 09-10-2003 12:52:40
tom, the product you described sounds like urethane. Some of the tank liner products I have seen are white and simply harden by the evaporation of the solvents. They seem to me to be similar to plastisols. I never have used a urethane tank liner.
