JD 2010 starter
Lindsay
09-10-2003 09:12:47
Does anyone know if a starter from another tractor will replace the Prestolite or Delco starter from a diesel JD2010. No used units available in Australia.
Thanks.
Joe Stewart
09-11-2003 18:09:43
 Re: JD 2010 starter in reply to Lindsay, 09-10-2003 09:12:47
The JD parts manual lists Delco Remy part numbers 1108672 and 1107573 for 2010 diesel tractor serial numbers 010001-026873. It lists Delco Remy part numbers 1107523, 1107556 and 1107573 for 2010 diesel tractor serial numbers after 026874. For 2010 diesel tractors after serial number 042000, there is also a Prestolite number that can be applied: MFX-8001A. The usual note on the number of teeth on the starter drive gear applies here. Count the number of teeth on your old starter - make sure your new starter has the same number of teeth. Do this so you do not tear up the teeth on your ring gear when you go to start your tractor for the first time. I have a spare starter for my 2010 diesel (nine teeth), but I imagine the shipping charge to the "Land Down Under" would exceed its value. I honestly do not know if these starters were used on other tractors, but it seems likely that they were. It might pay to go to the local tractor boneyards and perform cursory exams on the available Delco and Prestolite starters of similar vintage and trying to match the above part numbers. Good luck. Joe Stewart.
firedog
09-10-2003 17:18:56
I don't know if this helps but the starter from a JD 45 Combine will work.
Good Luck, firedog
