Governor on '45 A
Robert
09-10-2003 07:05:47
I've posed this question on another site, but haven't gotten much response, so will try here.
I had trouble working my tractor last Saturday---it just wouldn't make any power while working. It seemed to run fine just driving it, but when trying to disk with it, it all but died.
From the operator's seat, it didn't appear to me that the governor was doing anything---the arm would not move the throttle to the open position.
I got off, and tried to move the governor arm manually, but it was tight. I shut the engine off, and the governor moves the throttle to the wide open position.
I had the linkage adjusted like the manual said, but am wondering if there's an internal problem with the governor (spring, weights, etc).
ANY help would be appreciated!
F-I-T
09-10-2003 08:40:24
 Re: Governor on '45 A in reply to Robert, 09-10-2003 07:05:47
Robert:
You said you adjusted the linkage, which means with engine off, the throttle in wide open position, and the governor to carburetor link disconnected at the carburetor, the rod will be 1/2 to 1 hole short from connecting. This way when you "force" the link to connect, you are pre-loading the carburetor with just a little of the spring load from the governor arm mounted leaf spring.
After that, what I'd try is with the rod disconnected from the carburetor, run the engine operating the carb butterfly by hand, and with the other hand see if the goivernor has any action at all.
If it doesn't, you may well have an interal problem.
Frank-in-Tallahassee
70D // 855 // VAC
Robert
09-10-2003 09:47:17
 Re: Re: Governor on '45 A in reply to F-I-T, 09-10-2003 08:40:24
Thanks, FIT !
I'm going back out tomorrow to reinstall the carburetor (pulled the nozzle out of the DLTX 71, and every little hole was plugged up with rust), and will check governor operation then. Up until last Saturday, the tractor always seemed to have plenty of power. Thanks again for posting back!
