JD 420w backfires when running and giving me fits
Chris
09-10-2003 07:05:24
I have a 1958 420w. It ran perfect until I went to pull it into the sop and it started missing out. I finally got it started the other day and it labored bad for a while at an idle. Then I pushed the throttle up a little and it back fired evrytime the engine hit. I shut it off and can't figure out the problem. It has good spark to the points and they look OK. It has good plugs. The distributor doesn't appear to have moved at all. Can anyone help? Thanks.
Henry J
09-10-2003 16:52:26
 Re: JD 420w backfires when running and giving me f in reply to Chris, 09-10-2003 07:05:24
Chris
A quick way to check if a condenser is trash is to check for any continuity between the lead that comes out of the condenser and the condenser body. There should be no continuity showing there. That is with the condenser unhooked with anything else.
Dan
09-10-2003 12:12:27
I would check to make sure wires, plug and coil are tight and making good conniection, no moisture in dist contacts. Points are really critical with these also. Good suggestions below also.
Ellis
09-10-2003 11:26:54
I went through a similar situation last week with a 430W and traced the problem down to a faulty condenser. It was missing and backfiring to a point that I thought the muffler would burst. Runs excellent now.
Chris
09-10-2003 13:15:29
 Re: Re: JD 420w backfires when running and giving in reply to Ellis, 09-10-2003 11:26:54
Ellis, this is exactly what it is doing. It backfired to the point it almost blew the muffler off. I kind of thought that it might be the condensor because I have had that problem on another tractor, but I have never had one backfire that bad for that many revolutions. Thanks a million and I'll post back after this weekend to let you know if that fixed it. Also does the 420 have to have a specific condensor? I have a few other JD's that will only run right if they have a certain one. Thanks alot
Ellis
09-10-2003 14:31:23
 Re: Re: Re: JD 420w backfires when running and giv in reply to Chris, 09-10-2003 13:15:29
Chris, the only info I have on condensers for the 430 is # AT14465 or AT14468. The number for a 530 is 1900272 and changes up to the same condenser as the 430 uses. Any of the other tractors I do not have the info at this point. Ignition systems can sometimes be very frustrating. Hope you can solve it with an item that is relatively inexpensive and simple. On my 430W the tractor has a total of 12 hours from a complete rebuild with new Deere parts and the condenser failed at a local tractor show. Just a bit diappointing.
Henry J
09-10-2003 10:19:00
chris
I would do two things first off. Pull the plug wires one at a time. You should be able to isolate the bad cylinder easily. Pull the plug on the bad cyoinder and install a new one and try it. If that don't work, check the compression next. Good Luck
