3020 64 model PTO engaging in 2nd thru 8th gears(p
Pete R
01-19-2004 13:17:38
My problem is the PTO will engage automatically at about 1500 to 1600 rpm's, when you are in 2nd & all the way up to 8th gear.I have the tractor split right between the engine & where the clutch pack is mounted.I replaced the front plate of the clutch pack,the rings,(for C1,C2,& the PTO),& numerous other seals.Right now with the tractor off I can turn the PTO shaft by hand(with a 12 inch channel locks, & about 50 lbs of torque).Would it be a good idea to split the tractor again(right infront of the planetary pack) and repair the PTO brake, or would it be ok & hopefully the problem is just the clutch pack?One other question will a M&W turbo fit an early model 3020 that was on a 3010?
david val
01-20-2004 00:05:45
 Re: 3020 64 model PTO engaging in 2nd thru 8th gea in reply to Pete R, 01-19-2004 13:17:38
when the engine is off the pto shaft should rotate with some drag from the pto clutch. depends on oil temp, the focre you describe seems excessive.
connect a pressure gauge to the pto clutch test port and check pressure in all gears with the pto off. if you get pressure reading in all other gears and 0 in first, there is pressure leak into the pto clutch circuit. if pressure is 0 in all gears, then the problem is mechanical.
david
G-MAN - forgot....
01-19-2004 13:47:08
You should be able to turn the shaft with the engine off, as you can on your tractor. It takes hydraulic pressure to apply the brake, so when the engine is off, it's not applied. I don't know that it should turn that hard, though.
Pete R
01-19-2004 23:31:09
 Re: Re: 3020 64 model PTO engaging in 2nd thru 8th in reply to G-MAN - forgot...., 01-19-2004 13:47:08
I noticed when I was in 1st gear & at 1500 rpm's & plus,the PTO would not move and I had somebody walk behind the tractor and try to turn it with a large channel locks, it stayed right there.So I'm hoping the PTO brake was not damaged all this while.THANKS for the info G-MAN.
G-MAN
01-19-2004 13:45:33
I'd probably go ahead and do the double-split to replace the brake while I was close. Will the PTO pull any kind of a load when it engages like that, or can it be stopped fairly easily? If the brake is completely shot or not engaging, there could be enough drag from oil in the clutch pack to make the PTO turn. Also, when you get it back together, install a pressure gauge in the PTO and PTO brake circuit, to make sure your pressures are correct. I worked on a 4020 powershift a while back where the little arm on the PTO engagement valve was loose on it's stem, and it would gradually lose pressure, and it smoked the PTO clutch. A guy bought it from the local C-IH dealer and it smoke the clutch right after he got it. They redid the clutch but never checked the pressure, which was the cause of the problems. He brought it to us to be checked, found that they STILL hadn't fized the real problem, and took it back to them. It would have ruined another PTO clutch in no time.
