Building a 730 Diesel
Matt
09-10-2003 04:44:40
I have completely pulled down my 730 and now need some advice in how much and where to go. I want to mostly pull with the tractor but also use it to pull a disk and bush hog twice a year. I am thinking about boring it out and shaving the head a little, but I am not sure. Any advice would really be appreicated.
JDGnut
09-10-2003 13:35:12
 Re: Building a 730 Diesel in reply to Matt, 09-10-2003 04:44:40
No room to do any shaving.. the head is flat.. the pistons will be close to or will be sticking out of the block.. Just have the surfaces leveled the min amount... .125 pistons... lots of head work.. and fuel work.. good transfer pressure and you should be happy... or stroke it and use Cummins pistons and welded rods.. or have a set made... depends on how much you want to pay to play... JDGnut
matt
09-10-2003 13:47:33
 Re: Re: Building a 730 Diesel in reply to JDGnut, 09-10-2003 13:35:12
Okay I know some about engines and on the other hand I know nothing. I had thought about the .125 pistons but can I use the stock rods and be okay. As far as head work goes, do I need a 3-way grind and bigger valves and is that it. With the fuel do I need bigger injectors and a bigger pump. Thanks for the info.
buickanddeere
09-10-2003 20:19:10
 Re: Re: Re: Building a 730 Diesel in reply to matt, 09-10-2003 13:47:33
It will be impossible to set the HP difference between 45,90 or 125 thou over pistons. The wee bit of extra airflow will be negated by cooler cylinder walls due to thinner metal. Airflow from the intake stack to muffler is key. A high lift cam and 830 injector tips calibrated with the factory 13mm pumps will be lots. Mow much $$$ do you have to spend? The local winner of this years 10,000 class was a 720 rowcrop with worn 18.4x38 Good Year Traction torque tires inflated to about 10psi. He crawled down the track in 1st gear,hardly smoked from the exhaust and took yet another 1st place trophy.
Mike M
09-10-2003 06:24:47
First step is to have lots of money ready to spend. Somewhere close to what a good 4020 costs should be a good start. That's where I ended up at on mine. I like you said completely I hope this also means you will take a peak at the transmission while you have the side covers off as this would be a pain to go back in after you get a good powerful engine and find out it's noisy
and flys out of gear. Good Luck jump in and do it right the first time.
