G connecting rods, replace or repair?
Will P
09-09-2003 20:50:52
I have a 49G that I am rebuilding due to the wrist pin bushings cracking and spinning in the rod. The rod has been egged .014" from the bushings spinning. Should I have the rods trued up and make new bushings? I have access to a cnc lathe, so that is no problem. Or should I replace the rods? The crank looks ok. Both journals measure 3.3735 all around. Can I put insert rods on this crank?
Thanks for your help.
Will P
Doug
09-10-2003 17:02:08
 Re: G connecting rods, replace or repair? in reply to Will P, 09-09-2003 20:50:52
If you want to replace them, I have a set. Extras left over when I stroked it. I'll take $75.00 for the pair.
Will P
09-10-2003 20:11:25
 Re: Re: G connecting rods, replace or repair? in reply to Doug, 09-10-2003 17:02:08
Doug,
Your email address is not visible.
Please contact me at,
johndeereplowman"at"hotmail.com
Will P
JDGnut
09-10-2003 13:39:37
yes, you can put the insert rods on that crank.. I have switched them over without pulling the crank... but check the crank to make sure it is close to being true round... I would just buy a set of insert rods... If you want to reuse your rods.. because of cost.. but one of the bushings.. usually they are a little over sized.. (I think the last set I bought they were about $12-15 each) and rebore the hole.. Good Luck
JDGnut
Mike M
09-10-2003 06:29:18
I would go with what your budget can handle as both ways are the same in the end sounds like you might even have the skils and tools to make it better.
