D Clutch Disk Problem
Bob - Wyo
09-09-2003 19:31:57
Am I the only one having problems with the new JD single disk's? Right out of the package they look waxy or oil soaked, and slip very easy unless clutch is way over tightened.
This has happened on 2 D's now under load.
Every thing is clean and spotless inside and no oil or grease, but always one disk is always gummed up from itself as I said every thing else is clean.
Also left one set for 8 days with the clutch engaged and when I went to put it in gear the clutch was stuck, yep the inside one had done the same and was stuck tight, so now leave clutch disengaged while parked till I round up some old style disks, as that cured the one.
Just wondering if anyone else is having the same problem, don't have it with the old disks anyway.
Just my 2 cents on this,
Bob
