Hey there Eric, not to worry mate, Im sure the old girl can be made to run. (Have you tried a pull start?? maybe shes tight) You may just be floodign her also, are the plugs real wet if you check them after a failed start???? If so, clean and dry and try less choke etc and see what she does. Try the simple thigns first before all that below, like not flooding her and havign clean non fouled dry plugs maybe. First, you say youre getting a good spark, so does it ever backfire (maybe timed wrong or 180 0ut) or kick the flywheel backwards when you turn her over (maybe timed too fast) or does it ever pop or do anything at all????? ? Does the mag snap sharply when youre cranking her over??? It needs to snap at hand crank speeds (winds then trips spring) or else it cant fire. Do both plugs produce a good visible blue spark and not a faint thin wimpy yellow one??? What did you do or observe to make the statement she has fire???? Lets get back to the basic timing and without knowing what mag you have (I assume a mag on hand start, if not, post back your ignition and I will revise my advice), I can still give you some general advice which ought to hold basically correct, regadless. Remove the plugs and then check this below: When the left (flywheel side) piston is up to TDC on its compression power stroke (you can tell by compression and use a wire etc to find TDC) the Left Hand Impulse timing mark on the flywheel should be at 3 o clock in line with a flat mark on the tractors side, if the flywheel is on the correct spline that is. IS IT ????? ?? ALSO At that position, the governor shafts end female drive slot which the mag fits into (if cam to crank and cam to governor are all in time) should be flat horizontal fore and aft. ALSO At that position, the mag should just snap over (when LH Impulse flywheel mark passes the 3 o clock flat mark) and fire the left cylinder out the leading (top on many mags) cap terminal, then 180 later, the lagging cap terminal (bottom on many mags) fires the right cylinder on its compresion TDC. IF ITS AS ORIGINAL, but can be 180 out and need a wire reversal (see below) on some mags and still run. On the non gear reduction mags (turn at crank RPM), like the Wico C and XH series and some Fairbanks, they fire at BOTH the power and exhaust TDC's, therefore, even if the mag were 180 out in that governor shaft drive slot, they can be made to run by a simple plug wire reversal. I.E. if she backfires badly etc., it may be 180 out but reversing the wires will make her run. HOWEVER, if its a gear reduction type mag, a wire reversal wont make them run right if they are installed out of time. Thats why in my timign procedure above, I say use the left hand cylinders Power Stroke TDC for settign when the mag fires that cyliner and then the right cylinder 180 later. Once you verify the general timing above, fine tune it by loosenign the mags mount bolts and rotate it CCW to advance and CW to retatrd so she snaps and fires right when the flywheels Left Hand Impulse mark passes the flat mark at 3 o clock. If too soon before, she may kick back, if too late after, shes hard to start. She may just be stiff and needs a pull start to loosen the old girl up a bit, have you tried that????? Even if the mag had a spring type problem and didnt fire at hand crank speeds (dont produce the sharp snap) she could run finme if pull started. I havent addressed carb problems, but first insure the timign, maybe pull start her, then post back or e mail me at [email protected] or call me at (812) 824-4608 and I will give further advice if needed. The carb rough in settings are closed then 1 3/4 to to 2 turns out for the idle needle and 3/4 to 1 out for the load needle and be sure you have clean fresh water free gas. If the plugs are not clean or fouled, try a fresh set (Maybe Autolite 388) and see what happens first. If the timings fine and a good spark but shes flooding, clean the plugs and try a restatt with less choke. Good Luck n God Bless John T Nordhoff in Indiana
