Anyone use a 50 w/ a 6ft bushhog?
Tye
09-09-2003 15:06:54
Cutting a litte with a 5 ft bushhog behing my JD 50 today in pretty tall grass and it did fairly well. In medium and thinned out grass could I get away with a 6 foot tag along bushhog? Opinions are welcomed and appreciated.
ChuckW
09-10-2003 07:33:15
 Re: Anyone use a 50 w/ a 6ft bushhog? in reply to Tye, 09-09-2003 15:06:54
personally I feel 6' bushog too much for a 50, better served on a 60/620/630. I always use a 5' on my 530. See no point in large size when you have to go to creeper gear to operate. You will be putting an overload on your pto drive assembly and clutch.
Tye
09-10-2003 02:18:45
Thank you for all the comments here. I think I might start looking for a 6 footer. Thanks again
Ron
09-09-2003 21:39:28
My 1952 "B" runs our Bush hog (6ft) in average 8 week old grass and weeds in 4th gear... In 8ft tall two year old saplings (thick) it may be in 1st gear... The "50" is supposed to have more power, plus Live PTO, so I would think it would be a perfect match for a 6' Bush Hog... A dual spindle mower might be heavier,and be a little too much drawbar weight without front weights..ofcourse that depends on wheather the wheels are set to the rear, or on the sides...
Brokenwrench
09-09-2003 17:11:23
You could probable pull a 7' with the 50 if it is a multi spindle mower(2or3 sets of blades). They pull alot easier than a single spindle. Just make sure it is adjusted properly,cutting slightly lower in the front so the blades aren't trying to cut the same grass twice.
RayP(MI)
09-09-2003 16:53:36
We used a 6 footer -pull behind on a '49 JD B. This is the predecessor to the 50. Worked fine, even in very rough heavy going. You'll want to gear down in those conditions anyway.
