Randy, There are lots of good rebuild shops out there. There are also lots of not-so-good rebuild shops out there. I have had both good and bad experiences with different entities. I have even seen the higher priced person perform the lower quality job. The only thing that has remained a constant for me in the last 6 years, is that when receiving a carb back from Robert's Carburetor, it will work as intended! One time, I bought a hard to get carb from a reputable source (Robert didn't happen to have this particular one in stock at this particular time). The carb looked absolutely beautiful both inside and out - a showpiece as a matter of fact. However, it would not work quite right on my Deere. I sent it back to the source, where they rebuilt it, and even tried it on a tractor to see the problem first hand. They didn't really see any problem and sent it back to me. Upon installation on my tractor, I still was not pleased. Although the source was very helpful, and genuinely trying their best, I could tell that to send it back again would get me nowhere. I then sent it to Robert. He took a quick look at it, and immediately noticed that the wrong butterfly was installed. The correct one was only .015" larger in diameter, but this made all the difference in the world! Robert sent it back to me, and it has worked perfectly ever since. The moral of the story is that it takes less time to do it right the first time, than to fix a job that was not done right the second time. Again, I do not wish to infer anything bad upon any other shop, but would like to let you know that I find the quality of work from Robert's Carburetor to be superb. You will not be messing around with the carb after you get it back. Your carburetor problem will be solved!
