Air in system causing problems?
curt
09-08-2003 19:12:51
Is it possible to have air in the fuel system and the tractor still crank and run and then sputter and die like it is starving for fuel? I'm sorry for asking such basic questions but I have never owned a diesel and know very little about them.
DON
09-09-2003 13:43:41
 Re: Air in system causing problems? in reply to curt, 09-08-2003 19:12:51
CURT , IF YOU HAVE A ROOSA-MASTER INJ. PUMP, THE GOVERNER RING (RUBBER) HAS PROBABLY BROKEN UP INTO PIECES AND PLUGGED THE RETURN FUEL LINE. THERE IS A TIMING WINDOW ON THE SIDE OF THE PUMP WITH 2 SCREWS ON IT , LOOSEN THEM UNTIL FUEL LEAKS OUT . THE TRACTOR WILL RUN THIS WAY. IF IT DOES YOU NEED A PUMP OVERHAUL. DON
F-I-T
09-08-2003 19:18:37
Curt:
What make and model of tractor ? A diesel should run without spitting/sputtering/ Clogged filters or air getting into the fuel lines can cause problems. So can a partially closed sediment bowl valve or dirty sediment bowl screen
Tell us more.
Frank
F-I-T
09-08-2003 19:29:44
 Re: Re: Air in system causing problems? in reply to F-I-T, 09-08-2003 19:18:37
Is this the same 2630 from below (serves mne right to read from the top down...)?
Curt, do the simple stuff first. I don't have a book in front of me, and we have some modern JD Techs on this page, so let's hope they jump in here to help, but anyway....
Check if there is a below the tank shut off valve, and make sure it is on all the way. Next, the line should go through a block mounted fuel transfer pump. This is where a hand primer lever or button pump would be located it so equipped. Then the fuel flows through a sediment bowl arrangement. Clean this bowl and its screen. Next the fuel flows to the fuel filter or filters. Starting farthest from the injector pump, find the first bleed screw, loosen the bleed screw, and while cranking the engine, crank until the fuel flow is bubble free. Tighten that bleed screw before you stop cranking. Do the same on the next filter if so equipped. Now check carefully for a bleed screw at the input of the fuel line to the injection pump. Bleed as before.
If you can't find any bleed screws, don't guess because you might loosen somnething that should not be disturbed. You can probably achieve the release of any air by cracking the nut on any injector where the steel line attaches to the injector. Crank until no bubbles in fuel, and tighten before you stop cranking.
That should get you going if you have a simple bleed need or a dirty screen. When was the last time you changed the fuel filter ?
Frank
Indydirtfarmer
09-09-2003 10:03:31
 Re: Re: Re: Air in system causing problems? in reply to F-I-T, 09-08-2003 19:29:44
Now I'm confused. F-I-T says that he's wrong for reading from top to bottom. That's what I always do. (My dad told me a long time ago, that when you have a problem, go straight to the top)
