Front weights for a JD 50 on a Late-Styled Model B
Dennis
09-08-2003 19:08:20
Does anyone know if the front weights for a Model 50 (B3281R and B3280R) will fit on a Late-Styled Model B?
Brokenwrench
09-09-2003 17:20:09
 Re: Front weights for a JD 50 on a Late-Styled Mod in reply to Dennis, 09-08-2003 19:08:20
Not entirely sure, but I believe they will fit. I have a customer with a Late A that has the 801 hitch on it and he has the frame weights on it. I don't know if they were a direct bolt on or if he redrilled some holes.
JDVan
09-08-2003 23:22:45
Not that I am aware of. These two piece weights were made specifically for the JD 50. There was a different two piece front frame weight set also made for the 60 & 70. I'm not aware that these two piece weight sets will fit on the equivalent Letter series.
The two piece weight sets are quite rare and are quite valuable as collector items.
Pat
09-10-2003 06:01:49
 Re: Re: Front weights for a JD 50 on a Late-Styled in reply to JDVan, 09-08-2003 23:22:45
You are right. I was lucky enough to buy a set that was advertised as fitting a "B". Wouldn't, but with a lot of washers, would fit a 520. Now have a 50, and they sure look nice on it! Pat
